Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-27-2014, 03:01 PM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
9.5" Differential Pinion Bearing Question
1991 V2500 Suburban, 14 bolt/9.5" rear end.
Are the inner and outer pinion bearings the same for the rear differential? Can't tell from alldata...
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 08-27-2014, 03:12 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 9.5" Differential Pinion Bearing Question
No, they are different sizes. Inner is much bigger.
Old 08-27-2014, 03:39 PM
Roger that, thanks. Looks like costs of inner/outer bearings/races and the associated tools will be as much as a used rear-end i found for $150. I'm thinking about simply swapping rears, especially since new one came from truck with only 70k miles.
Three more questions:
1) New rear is from 2WD truck. Any difference between the 2WD 3/4 ton 9.5" rear end and the 4WD 3/4 ton 9.5" rear?
2) Is the GM 9.5" rear a standard width, shock mounts locations, i.e., would a rear from a '94 C2500 be basically a drop-in for my '91 V2500?
3) I would like to just swap my diff into the new rear, the 2WD is 3.42 and I'm assuming mine is prob 3.73 or 4.10 since it's 4WD/v2500. Will my diff work with the 3.42 pinion? (i.e., is ratio solely dependent on ring gear and not on pinion?)
Thanks for help,
Alex
Old 08-27-2014, 04:50 PM
gmtech1's Avatar
I don't think there is a difference between 2wd and 4wd rear ends....but I'm not 100%
The '94 should bolt into the '91 without a problem, assuming shock mount/sway bar mounts are the same...
No. don't mix the two. Gear ratio's use different ring and pinion gears, they are also a matched set, swapping as you are suggesting would not be a good thing, the transfer case would REALLY not like that. Be sure the new/used rear end has the same gear ratio.
Old 08-27-2014, 05:34 PM
Gotcha thanks! For what it's worth, thru research I've found a couple of people on other boards saying that the 4WD axles are a bit wider than the 2WD.
Anyway, based on having to match the pinion/ring gears, looks like there may not be much labor saved by going with a new rear end...
