Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-26-2014, 04:17 PM
kawtool kawtool is offline
2001 Montana Glove Box Lock
The glove box door got jammed or something and I can't close it. It seems the locking mechanism is jammed open or closed and the handle does not go to the close position even with the door open. How do you remove the lock after taking out the 2 screws? Or is it because the latch is bent?
Old 08-26-2014, 04:45 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: 2001 Montana Glove Box Lock
After removing the two screws, the latch assembly should push out the front of the glove box door.
Old 08-27-2014, 10:22 AM
The latch assembly does not want to come out no matter how hard I push it or shift it around. Someone on another site said hammer it out using a piece of wood as a punch but I'm afraid it would break the glove box front. And if it is that hard to get it out, how do you install a new assembly?
Old 08-28-2014, 03:34 PM
Got it! Instead of a hammer, I used a long needle nose plier opened a bit and pushed down on the latch assembly in an area closest to me. It popped out and I fixed the latch, and snapped it back in. Saved perhaps $70 to a $100 if a dealer had to repair it from some posts I saw.
