Old 08-26-2014, 07:01 AM
94XLT 94XLT is offline
Fuel Pump
I have a 99 Buick LeSabre and it died while I was pulling into a parking lot. It wouldn't start back up. I tried listening for the fuel pump and nothing. It's not priming or making any noise. Once I got it home I replaced the fuel pump relay. Still nothing so then I changed the fuel pump. Still nothing. I'm stumped. I'm going to check all the wires tonight to make sure I got them on right.
Is there any other relay or fuse on these cars that I can check? Has anyone else had any problems like this and if you did how did you fix it? Any knowledge or ideas on this would be a great help.
Thanks
Frank
Old 08-26-2014, 07:23 AM
maxwedge maxwedge is offline
A990 racer
Re: Fuel Pump
Make sure you have a good ground to the pump.
Old 08-26-2014, 09:51 AM
Tech II Tech II is offline
Re: Fuel Pump
I agree with Max......check for power AND ground.....
Disconnect the harness to the fuel tank, and attach a test light to the two wires of the fuel pump circuit(grey wire and the larger(dia.) of the two black wires), on the harness side, not the tank side...
With key on, light should come on for two seconds....when cranking, it should be on constant......
If it does not light, individually check one leg for power(grey), and check the other for ground(larger diameter black).....
Old 08-26-2014, 05:12 PM
Re: Fuel Pump
Thanks for the post guys. I just got home from work so I'm going to see what I can find. I will keep you posted.
