Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 08-26-2014, 04:31 AM
nticmates nticmates is offline
Steering wheel vibration
Hello,
I have a 98 Toyota corolla and every time I am moving and then I step on the brakes, the steering wheel starts to vibrate. I have changed the rotors, the break pads, the calipers and even changed the brake master cylinder...but still vibrates when I step on the brake pedal and I have done wheel alignment and balancing... Please help me with solutions.
Thanks
Old 08-26-2014, 12:21 PM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: Steering wheel vibration
Check your wheel bearings, ball joints, and tie-rod ends.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 10-23-2014, 05:39 AM
beir's Avatar
beir beir is offline
old dog learnin new trick
I have a 97 corollary..had clutch changed now car has vibration issues at idle and @ 1500-2500 rpm read somewhere it could be engine mounts seeing car has 250k on it sounds lodgical gonna look into it.will reply if I find problem. If anyone can help please reply
Old 10-27-2014, 06:08 AM
beir's Avatar
Looked @ work done by trans ship..found engine mount in backwords ..was touching metal to metal ..corrected problem ..got rid of some vibration now I think motor is just running rough..gonna try distributor cap,rotor & plugs also fuel injector cleaner ..keep ya posted
Old 10-29-2014, 05:38 AM
beir's Avatar
Well changed plugs, cap & rotor..still vibrates steering wheel @ idle..was told by friend to check rear engine mount. I didn't realize car has 4 mounts & where it's mounted sounds right. If this the problem I will post it I know after looking at pics of it there is only one way to install it.
Old 11-03-2014, 05:30 AM
beir's Avatar
Checked rear engine mount ..it was tight ..took pry bar & lifted engine while running & vibration went away..inclement weather prevented me from changing it...get 2 it this weekend. & will post results
Old 11-03-2014, 05:36 AM
beir's Avatar
I lifted engine @ right engine mount...forgot to add
