Go Back   Automotive Forums Car Chat > Mitsubishi > Raider
Old 08-24-2014, 01:24 PM
chrissavage28 chrissavage28 is offline
transmission problems
My 06 mitsubishi raider drove fine parked it then the next day went to drive it and it wouldnt drive. I gave it more gas and it moved realy slow. It popped up p0562 and a p0700 (system low voltage and trans control sys malfunction). Led me to think wiring problem. I tried to look at wires couldnt see much wiggled some connectors. I then tried to drive again and it did the same thing but turned the check engin light on this time. It popped a nother code P0841 (trans fluid press sensor/switch a ckt range/perf) i erased codes the p0841 hasnt popped up. Im in the dark dont know what to do i would appreciate any help or advice.
Old 08-30-2014, 07:08 PM
Re: transmission problems
I fixed the problem. I did research found a guy with a jeep that had the same symptoms as mine same codes. His was a cracked filter. I pulled the trans pan and there was a cylinder filter sitting on the pan. It must have vibrated loose. So i replaced the filters and fluid and it works fine. Just posting just in case any of rhe 100 views were looking for a solution.
