Go Back   Automotive Forums Car Chat > Toyota > T100
Old 08-19-2014, 11:02 PM
BishiRST BishiRST is offline
Exclamation 96 T100 will not run, plx help
Hello all, I recently came across a problem that has be completely stumped. I was helping my friend with his T100 last weekend, it has a 3.4L V6, auto 4x4. We changed the cam seals, oil pump seal, rear main seal, valve cover gaskets and torque converter seal. after that, the engine was pressure washed with a Harbor Freight electric pressure washer (weak ) and then reinstalled into the truck. after we reconnected everything, filled it with fluids and changed the oil filter, we tried starting it. it came on for like 2 seconds then quit. It's been doing that since Sunday, there is a CEL code P0340, I changed the cam position sensor with a brand new one, but the light is still on and the truck will not run ... Any help offered will be greatly appreciated. Thank you in advance.
Marvin
Old 02-16-2015, 12:55 AM
BamZipPow BamZipPow is offline
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow
Wink Re: 96 T100 will not run, plx help
http://www.obd-codes.com/p0340
Perhaps you pinched the wiring harness? You will need to do a continuity check from the sensor connector to the ECU connector. I would do a resistance check as well to make sure the harness hasn't been compromised or shorted.
Old 02-21-2015, 09:29 PM
fourwd1's Avatar
fourwd1 fourwd1 is offline
AF -Advisor
Start with the basics.
Are you getting spark to th eplugs?
Are you getting fuel to the injectors?
84 4Runner - ARBed 5.29s F&R, 4.7 & 2.28 t-cases, Chevys, AP x-over, BudBuilt x-member, 2" drv trn lift, 36" TSLs, 30 spline Longs
80 something p/u - Buick 231 V6/TH-350 trans, Holley 4 bbl, Weiand intake, dual batts, dual tanks ...
89 4Runner - stock
2000 Isuzu Trooper + 2010 Sonata
