Old 08-19-2014, 07:13 AM
l1driver l1driver is offline
Send a message via AIM to l1driver Send a message via MSN to l1driver
Air Bag light
I have a 2000 Silverado 1500 Z71, 252,000 miles, 4.8, Automatic Trans. Yesterday the airbag light on the dash came on and will not go off. any ideas what would cause this?
Old 08-19-2014, 08:16 AM
j cAT j cAT is offline
Re: Air Bag light
this maybe the sensor in the front of the vehicle. some have had this cause this. first see if the fuses are good.
Old 08-19-2014, 08:22 AM
Re: Air Bag light
I checked the fuse in the fuse box on the drivers side of the dash and it was good. Is there more than one fuse for the air bags?
Old 08-19-2014, 03:35 PM
Re: Air Bag light
check all the fuses just to be sure. then look for the front ABS sensor crash impact device . see if it is connected and secure. then go to scrap yard see if you can get one off a wreck for testing. if it fixes it buy a new sensor. post back what it was .
Old 08-19-2014, 06:09 PM
maxwedge maxwedge is offline
A990 racer
Re: Air Bag light
Needs to be scanned for srs codes.
Old 08-19-2014, 09:06 PM
Tech II Tech II is offline
Re: Air Bag light
I agree with Max.....reading the code will point you in the right direction....
Old 08-19-2014, 09:50 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: Air Bag light
Yep. Get the codes checked. While it probably is a impact sensor, it could be anything else also. It's not legal in my state to sell used SIR parts, too much liability.
Old 08-21-2014, 09:08 AM
Re: Air Bag light
does it take a special tool to scan for SRS codes? I put my scan tool on it and no codes came up. Thanks J cat for the suggestion. Local salvage yard does have one I can get for testing purposes.
Old 08-21-2014, 09:53 AM
Re: Air Bag light
Your scanner probably can't read SRS codes, which are "B" codes...usual scanners can only read "P", or Powertrain codes....
OTC makes a code reader, that reads Powertrain, ABS, and SRS codes, if you are so inclined to get one....
Old 08-21-2014, 11:00 AM
Re: Air Bag light
now if these air bag codes were included in a typical scanner/code reset tool available for a hundred bucks I would have stated to get this code and post it .. this code will cost you about a hundred to get to have a shop/dealership get it..
also my info reports have stated that the fuse or the front impact sensor is the cause with this vehicle . if this code will not clear after testing then it will cost you a lot more to fix.
Old 08-21-2014, 01:30 PM
Smile Re: Air Bag light
I went and had the code read at lunch. Local Auto Electric shop checked it for me for $35. Turns out it was the Passenger Air Bag on/off switch. Picked one up at local salvage yard for another $35 and light is out. Dealer wanted $90 for switch. Thank you to everyone for the help.
Old 08-21-2014, 01:43 PM
Re: Air Bag light
do you use that air bag switch much ? I never operated that switch since I purchased my 2000 SILverado new. that is a weird one ..
