Go Back   Automotive Forums Car Chat > Ford > Explorer | Explorer Sport Trac
Old 08-17-2014, 06:37 PM
ericw6767 ericw6767 is offline
1993 explorer sport trans.problem
I have a 1993 Ford Explorer Sport manual 5 speed transmission I just put a new clutch in it newslave cylinder when you put it in gear and you can push the truck around I took out everything was fine I don't want to put the Trans back in if it's the problem could it be the transfer case allowing the free spin of the driveline?
Old 08-17-2014, 11:10 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: 1993 explorer sport trans.problem
Is this the same symptom that caused you to replace the clutch and slave cylinder, or something that just happened?
-Rod
