Old 08-13-2014, 06:27 PM
marvs10 marvs10 is offline
Question 2000 s-10 gear indicator light does not light up-bulb good
2000 S-10 gear indicator light does not work except when switch is in accessory position. When in run or start position there is no light. Light worked until I replaced the brake light switch. What could I have done to cause this.
Old 08-14-2014, 07:44 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 2000 s-10 gear indicator light does not light up-bulb good
Usually caused by indicator light bad connection in cluster.
But check for wiring damage also.
MT
