Old 06-28-2003, 06:07 PM
91BLKsi 91BLKsi is offline
Send a message via AIM to 91BLKsi
What do performance Cams do?
What performance cams do?
Old 06-28-2003, 07:37 PM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
Ummm - tough question... make your engine perform maybe???????
Try increasing lift and duration on the lobes so as to let more air/fuel mixture in on the induction cycle as well as the exhaust cycle (depending on the profile).
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 06-28-2003, 07:41 PM
Any more help...Beacause i dont get what your saying..HELP
Old 06-28-2003, 07:42 PM
jeef jeef is offline
Send a message via AIM to jeef Send a message via Yahoo to jeef
what he said... and cams are generally a really good mod, especially if they are tuned.. you can get a lot of power from a good cam set up
90- crx si w/ a D16a Vtec and a few goodies, oh and 60k miles on it heh
Old 06-28-2003, 07:51 PM
http://auto.howstuffworks.com/camshaft.htm
there is the explanation
Old 06-28-2003, 09:17 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
a cam will increase the amount of air/fuel mixture going into your cylinders by keeping the valves open longer, for a general explanation.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-28-2003, 10:04 PM
Setanta's Avatar
'99 PY DC2R
'85 BBS BMW E30
Old 06-29-2003, 01:10 AM
CRX89 CRX89 is offline
They give more hp. Bigger cams shift the power band to higher RPMs and you loose lowe end torque. The have bigger lobes and bigger lobe seprations. If you run a big cam youll want more compression as well to take advantage of it as well as a ported head and intake manifold that will flow with the powerband of the cam. Big cams suck for daily driving but rock at the track.
Old 06-29-2003, 01:16 PM
91civicDXdude's Avatar
....and thus, VTEC is born. big cams suck at lower rpm because they're tuned to make power where it matters, in the higher rpms. and yes, this kills low end. and then VTEC was born. you can still have drivability in the low rpms, plus the high performance big cam at higher rpms where it is needed.
If you ask me though, take a non VTEC engine, put VTEC spec cams in it, and it will perform like a VTEC.
Old 06-29-2003, 05:07 PM
Setanta's Avatar
The performance profile you mean, the cams themselves won't fit
'99 PY DC2R
'85 BBS BMW E30
Old 06-29-2003, 08:43 PM
awww shit you mean i can't put vtec cams in my ls1???? i had my hopes so high
Old 06-29-2003, 08:53 PM
crxlvr's Avatar
you wanna hear some dumb shit, this kid at my tech school said he had a mustang cam in his ITR motor, what a moron.
same kid that said he had that motor, 3 KKK 60PSI turbos, 2 50gal drums of nos, no intercooler, a CF Crankshaft, and a spinning BOV, with only 550hp, all this inside an 87 civic hatch.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 06-29-2003, 09:59 PM
but of course, notice i said vtec spec cams, meaning the same lift/duration of a VTEC cam, but a non VTEC setup.
Old 06-29-2003, 10:03 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
ha ha ha...wish they had a flag for bull shit. (i know there was but they took it away)
oh well, this will have to do...
PeacE
Old 06-29-2003, 10:09 PM
i talked to a local "honda enthusiast" today, it was almost as bad as that but not quite.
he said his friend has an 88 integra, "you know, the ones with the ZC, 138hp" , well anways, this kid argued with me that he can take this "138hp ZC" and bolt it right into his 89 CRX
New 2010 Impreza, no WRX or STI model, what can I do to add to the power/ performance redslayer2547 Impreza/9-2x/Outback Sport 0 08-23-2010 01:17 AM
Single Cam Mods...what should we do? GURLSVTEC Engineering/ Technical 26 02-26-2010 05:29 PM
What performance parts do I need for 95 Riv caseycane Riviera 1 10-15-2005 11:18 PM
GTI performance parts, what should i do? PatsGTI GTI 4 01-29-2004 11:53 PM
what performance cams should i get? Kinkster Engineering/ Technical 1 07-12-2002 10:19 AM
