Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 08-12-2014, 02:19 PM
thegreenhornet95 thegreenhornet95 is offline
350 tbi knocks (rattles)
I have 1995 5.7 tbi that knocks for a few seconds on
start up. It does it in the morning after it sat up over night &
if it set up for a hour or two. It doesn't knock any after
it knocks then. What could this be?
Old 08-13-2014, 07:46 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
Re: 350 tbi knocks (rattles)
Check your oil level, is it low?
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 08-13-2014, 08:03 AM
j cAT j cAT is offline
sound on the internet is hard to determine cause. carbon-ed rings will do it. also some coolant could be leaking into the cylinder.. do a compression test. also pressure test the cooling system..
add 3-4 OZ of marvel mystery oil to the fuel. this is a good cleaner and helps to remove carbon deposits if used regularly. old engines will last longer as it helps keep the combustion chamber clean.
this is an oil not a solvent. very safe to use and has a record of fixing dirty engines / fuel systems for many decades.
