Old 08-11-2014, 08:03 AM
skydivesteve skydivesteve is offline
98 taurus front end troubles
good morning forums. I tried searching before posting this but didn't find anything. I have a 98 Taurus and it keeps eating the outer edge of my front tires. suspension has no play at the wheels. thinking either the struts or needs an alignment but would like some ideas before I spend money I don't need to. any ideas would be greatly appreciated. thank you
Old 08-11-2014, 09:02 AM
aleekat aleekat is offline
Re: 98 taurus front end troubles
Alignment, toe issue more than likely.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
skydivesteve (08-11-2014)
Old 08-11-2014, 10:23 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Some places offer free alignment checks, call around and ask. As Aleekat said probably a toe issue, too much toe in, or could also be excessive positive camber. Get the alignement check first unless the struts are worn/leaking, then replace the struts and follow up with the alignment.
The Following User Says Thank You to gmtech1 For This Useful Post:
Old 08-11-2014, 10:41 AM
ok thanks I was thinking the same just wanted another opinion
Old 08-15-2014, 04:16 PM
drdisque's Avatar
drdisque drdisque is offline
Send a message via AIM to drdisque
definitely get the camber checked. If you hit something with the wheel turned it can bend the lower control arm and the alignment seems right and it drives OK, but it has a ton of positive camber and chews outside edge of the tires.
Dr. Disque -
Current cars:
2008 BMW 135i M-Sport
2011 Mazda2 Touring
Past cars:
2007 Mazda 6S 5-door MT
1999 Ford Taurus SE Duratec
