Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 08-10-2014, 11:50 PM
wyodan59 wyodan59 is offline
abs breaks
Hello. I've been trying to help a friend with his 98 gmc. When stopping the breaks are normal until getting slow then the abs motor comes on and the break pedal sinks to the floor. The truck stops but the abs motor runs constant until you release the pedal. This is happening on dry roads. What is there to check before condemning the abs module?
Old 08-11-2014, 09:47 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Re: abs breaks
Check both front hubs for play. Pull both the speed sensors out of the hubs and check for a rusty build up on them. If there is then that hub assy will need replaced. If not, there still is a problem with one or both front hub assy's. With the year and I'm assuming high mileage, probably best just to replaced both front hubs.
Old 09-07-2014, 07:57 PM
old_master's Avatar
Advisor/Moderator
Re: abs breaks
Very common problem, here's how to diagnose it: http://ww2.justanswer.com/uploads/GM...s_bulletin.pdf
You have to know how it works,
to figure out why it doesn't.
Old 10-14-2014, 02:19 AM
thzpcs thzpcs is offline
Re: abs breaks
Sounds like you need new ABS sensors, which you can grab here.
Old 12-19-2014, 11:17 PM
Re: abs breaks
Hello. I did replace the front wheel speed sensors. The lights didn't go out. I started to check wiring and grounds. When I pulled the power plug off the abs motor the ground was covered with green blue slime. I cleaned it all up and made sure there was good contact. plugged it in and started it up and the lights went out and have not come back on. Glad to have the lights off. Thanks for the help!
