Old 08-07-2014, 07:32 AM
Nino Furicchio's Avatar
Nino Furicchio Nino Furicchio is offline
Lancia rally 037 wheels & tires WIP 1:10
Hallo,I was a few years away from the forum due to the birth of my daughter and consequent stop of any modeling activity, now I restart little by little and I decided to accept the challenge of building the 037 wheels in 1/10 scale unfortunately do not have enough information and I would need your help to get at least the measures of all depth measurements taken from the hasegawa kit, if someone wants to share other information would be a great thing, I will build the wheels on a lathe and milling machine with the divider (may be this the right word?) and will post progress.
As for the tires I've already found and tested a plastic material that I think gives good results with slick tires due to the difficult to reproduce machining the tread pattern of a sculpted pneumatic.
The info that i've finded on the internet are measurements of the car, most important is the weelbase,and of course the wheels at the rear we have a 10"x16" and 8"x15" at the front.
So with this very little information i have printed a copy of the hasegawa's drawings finded on the internet in the right proportions (in this i have used the weelbase measure as a good base for the print) in this Photoshop helped me so much.
At this point the wheels in the drawing also have the right measures (height and lenght are not in scale in the drawing) and can be used for the approximate diameter of the various shapes of each wheel.
Have started the machining of the inside of a rear wheel,but without precise measures of the inside have stopped at a depth 12,5 mm. Actually the external diameter is 1 mm more than 16" (in scale) for the lip of the rim.
The ultimate Porsche thread?
http://www.automotiveforums.com/vbul...d.php?t=764148
Machining master
Old 08-07-2014, 11:56 AM
generationx's Avatar
generationx generationx is offline
Re: Lancia rally 037 wheels & tires WIP 1:10
Surely the best place to start is with the Tamiya 1/10th R/C wheels...
http://www.tamiyausa.com/items/radio...-58278-0444140
Old 08-07-2014, 02:15 PM
I think that those rims are wrong for a super detailed static model as they were adapted for a rc chassis from what i see also the design is without details,
for those reasons can't be kept in consideration for my project.
I'm looking for the measurements of the rims in the hasegawa evo2 037 kit 1/24 scale if a guy here in the forum that have the kit can measure it for me
Machining master
Old 08-07-2014, 02:22 PM
lovegt40's Avatar
lovegt40 lovegt40 is offline
ItaloSvensk
grande Nino..facci sognare.
Note the link u have in signature has lost all pics. If possible plz fix it, cause also I would like to adire your detailing process.
keep on postin'
Paolo - LoveGT40 Modelworks
website www.alsoldatino.com
my YT channel : https://www.youtube.com/channel/UCIp..._as=subscriber
FB: https://www.facebook.com/alsoldatino
Old 08-07-2014, 04:05 PM
puffyrs's Avatar
puffyrs puffyrs is offline
Hello
PM sent.
Old 08-07-2014, 05:44 PM
Martin: pm sent to you.
Luca:sono passati un pò di anni e vedo se riesco a ripristinare le foto.
A little gallery of my past works
this is a little part of the work done on the tamiya 935 1/12 scale
and a little part of the work done on the heller JS-11 1/12 kit also the tires are made at the lathe.
Machining master
Old 08-07-2014, 09:24 PM
CMalfitani's Avatar
CMalfitani CMalfitani is offline
Nino I can measure the Hasegawa 1/24 037 wheels for you. I will have access to my 037 kits on the next weekend, then I will measure and inform you.
Congratulations for this amazing project!
Best Regards.
The Following User Says Thank You to CMalfitani For This Useful Post:
Nino Furicchio (08-08-2014)
Old 08-08-2014, 04:55 AM
Thumbs up Re: Lancia rally 037 wheels & tires WIP 1:10
Best Regards.
Ok it would be great for me, I am momentarily stopped because I lack the steps to finish the inside and then cut the bar because I have to build the wheels in at least two separate parts.
Thank you for the comments !
Machining master
Old 08-08-2014, 07:51 PM
Hallo,today I had time so I tried to realize the prototype of the outside of a rear rim,
which is formed by a ring with appropriate diameters, the depth of the first shoulder is approximate,i will modify it before to cut out the finished piece.
Machining master
Old 08-09-2014, 09:23 AM
CMalfitani's Avatar
Nino,
I will inform you the correct dimensions of 037 hasegawa front and rear wheels until today.
Do you need a complete measurement or only width, diameter and offset?
Let me know!
Best regards.
Carlos Malfitani.
Old 08-09-2014, 11:38 AM
Nino,
Let me know!
Best regards.
Carlos Malfitani.
Carlos thank you again for your disposability i made a drawing of the measurements i need intended for both wheels type, front and rear.
See you soon.
Machining master
Old 08-09-2014, 12:04 PM
CMalfitani's Avatar
Ok Nino.
I will measure the wheel (front and rear) today when I came back of my work.
Best Regards.
Old 08-09-2014, 12:17 PM
Ok Nino.
Best Regards.
Ok great!
See you soon.
Machining master
Old 08-12-2014, 08:43 PM
CMalfitani's Avatar
Nino,
First of all, sorry for my delayed answer, I have been problems with my internet connection.
Following, the measurement of Lancia 037 1/24 Hasegawa:
According to your drawin's legends:
REAR WHEEL:
F=12,10mm
A=0,34mm
B=1,78mm
C=1,80mm
E=8,00mm
D=8,98mm
X=5,84mm (diameter)
FRONT WHEEL:
F=8,98mm
A=Not applicable
B=1,54mm
C=1,56mm
D=6,24mm
E=5,56mm
X=5,84mm (diameter)
I use to measure a Micrometer Mitutoyo precision 0,02mm
Best Regards.
Old 08-13-2014, 06:26 AM
Thank you, i just prepare a drawing for the machining job.
Machining master
