Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora > '97 - '03
Old 08-06-2014, 08:18 PM
wade623's Avatar
wade623 wade623 is offline
2002 jetta 5 speed manual oil change
I have just got a jetta and was looking to change the oil in the transmission some time in the future but when I look for a place to put oil back in I can't see any place to do it so I'm wondering if anybody can tell me where to put oil back in after draining it
__________________________________
Practice makes less imperfections.
Old 08-07-2014, 06:11 PM
DeltaP DeltaP is offline
Re: 2002 jetta 5 speed manual oil change
You may have to remove the insulation tray from below the engine/transmission if its still there to get to it. It's on the side of the trans facing the front of the car. It takes about 2 liters of 75W- 90 synthetic gear oil. Fill to bottom of plug hole,put plug in and with wheels off the ground,on jack stands run the engine in gear for a couple of minutes, turn off engine,pull plug and recheck. Should be to the bottom of plug hole, (let drain till it stops dripping). HTH
Old 08-10-2014, 11:07 PM
wade623's Avatar
thanks. ill check it out
