Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 08-05-2014, 07:16 PM
pvisser pvisser is offline
Send a message via MSN to pvisser
Hood Ajar
Hello.
2007 SV6 ext
On the dash it constantly says hood ajar.
We can press the arrow key and ignore for the ride, but next time you start there it is again.
Remote start doesn't work because of this error.
Is there a way to bypass the sensor?
Paul
Old 08-05-2014, 07:50 PM
aleekat aleekat is online now
Re: Hood Ajar
No. Safety feature so car isn't remote started while someone is working under the hood. Look at item 017 on this diagram:
http://parts.nalleygmc.com/showAssem...ssembly=399683
Edit: You may be able to put a jumper wire in the plug. But you'll need to test the switch exactly how it functions.
Post back, that's what makes Forums Work.
Old 08-05-2014, 08:23 PM
Ah I c.
The price is not so bad either.
Just wonder if there is a way to be sure it is the sensor that is failing.
Paul
Old 08-05-2014, 08:35 PM
Re: Hood Ajar
I'm pretty sure it's not a sensor but a simple switch. Since I don't know how it functions:
If it was my car, I would pop the hood so the ajar light is on. Then look for the plug. Disconnect it. If the light stays on, then switch open triggers the light. Put a jumper wire on the plug end and see if the light goes out. But I would also look if there are any adjustment bolts that allows you to move the latch up/down. It may some as simple as that.
rockauto.com has a better picture.
Old 08-06-2014, 07:31 AM
Tech II Tech II is offline
Re: Hood Ajar
It's usually the switch...then the code has to be cleared for the remote start to work...
Old 08-06-2014, 04:12 PM
I tried to jumper across both wires on switch. No change
I ran a wire to ground from each wire. No change.
Left the plug un plugged. No change.
Paul
Old 08-06-2014, 06:31 PM
Re: Hood Ajar
But did you clear the code?
I think all you have to do is disconnect the switch, and then clear the code, and then try the remote.....
Old 08-06-2014, 07:22 PM
Ah, nope. I didn't clear the code.
I assumed when the bcm was satisfied the message of hood ajar on the dash would go away.
I have a cheap code reader/clearer should I be using that or is there a better method?
Paul
Old 08-06-2014, 09:11 PM
Re: Hood Ajar
Leave the switch disconnected.......If your reader can read the code, clear it......then see if it comes back....then see if the remote start works....
Old 08-20-2014, 08:48 PM
Unfortunately. My reader is an obdii reader..
Doesn't seem to read on this van.
Paul
