Go Back   Automotive Forums Car Chat > Dodge > Ram Pickup | Ram SRT10
Old 08-04-2014, 09:38 PM
bmklawt bmklawt is offline
1997 Ram, pulls to left for second when braking
I have a 1997 Ram 1500 when I apply the brakes the truck pulls to the left for a spit second then goes straight.
Example: doing about 40 MPH take hands off the wheel and slam on the brakes, truck pulls immediately to left, like I did a quick lane change then goes straight.
About a month ago I replaced a section of brake line going to left rear wheel.
Your help is greatly appreciated,
Bruce
Bruce
2014 Toyota Camry Hibrid
2005 Silverado Z71 5.3L
1997 Grand Caravan 3.3L
1997 Dodge Ram 1500
Old 09-03-2014, 12:04 AM
Re: 1997 Ram, pulls to left for second when braking
I replaced the front calipers and am still having the same problem, any one have any idea whats going on?
Thanks
Bruce
Bruce
1997 Dodge Ram 1500
Old 09-03-2014, 11:05 AM
gmtech1's Avatar
gmtech1 gmtech1 is offline
I'd replace both front brake flex hoses, the rubber hoses to the calipers. One is probably weak and expanding a little under pressure. Have seen these cause this issue several times.
The Following User Says Thank You to gmtech1 For This Useful Post:
Chris Stewart (09-03-2014)
Old 08-30-2015, 04:04 PM
Found that the bracket that holds the rubber flex hose was rusted and pinching the hose, pried the bracket open a little bit and that fixed the problem.
Bruce
1997 Dodge Ram 1500
The Following User Says Thank You to bmklawt For This Useful Post:
Chris Stewart (08-31-2015)
