Go Back   Automotive Forums Car Chat > Mercury > Mountaineer
Old 08-03-2014, 10:47 PM
spliceman spliceman is offline
02 4.6 won't crank, odometer reads all dashes
Mountaineer stalled while turning. Would not crank when I tried to restart. The odometer and temp read all dashes. Checked grounds, switched out relays and checked fuses. All looked good. Any suggestions?
Old 08-04-2014, 09:57 AM
Re: 02 4.6 won't crank, odometer reads all dashes
I followed some steps I read online and checked the PCM. The grounds seem to be good, although I don't think I'm getting power. Does anyone know how the power is fed?
Old 08-25-2014, 05:52 PM
Turned out to be the PCM diode.
Old 08-25-2014, 10:48 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Very interesting. Do you have any idea why a bad PCM diode would only cause issues when turning? When diodes fail they typically either fail open or fail shorted. I can't say I've ever heard of one failing intermittently.
-Rod
