Old 08-03-2014, 12:59 PM
andrew59it andrew59it is offline
Html
Why I'm not able to use HTML in my post? The buttons don't work, but in this post yes they work!!
Very strange
Old 08-31-2014, 06:21 AM
Re: Html
No hint....? I'm not able to place emoticon too.... the arrow of the point doesn't change when I pass over them....
Old 08-31-2014, 11:13 AM
rallymaster's Avatar
Re: Html
Did you check your configuration setup in your profile page...? if not wrong you should be able to specify it there...
Phil
Old 08-31-2014, 12:13 PM
Re: Html
Yes I checked... I found this in the faq:
"Some smilies can be accessed from the 'New Post' or 'New Thread' pages if your administrator has enabled this function."
Have I to ask to administrator??
Old 12-03-2014, 01:34 AM
Re: Html
Hello
about this problem I discovered when I post a message "HTML is off".... so I'm not able to insert smiles or edit the message format.... How to place html in ON?
I checked every setting in control panel but there is no option.
Thanks
Old 12-03-2014, 02:37 AM
Kjenjak's Avatar
Kjenjak Kjenjak is offline
Re: Html
Maybe some high security settings in your webbrowser?
<img src=http://www.automotiveforums.com/vbulletin/image.php?u=698755&type=sigpic&dateline=1361304198 border=0 alt= />
Old 12-03-2014, 06:51 AM
Re: Html
Thanks for the hint.... I usually use chrome which has the problem, tried with explorer and it works... don't know which kind of setting could be.....
Old 12-05-2014, 03:07 AM
Re: Html
Solved
It was a pop-up related issue. I have pop-up block in chrome with exceptions.
Thanks to Igor Sushko discovered to add into the excpetions staticaf.com
Old 12-05-2014, 03:13 AM
Re: Html
Sorry....
today doesn't work again..... :^(
But also with pop-up enable.....
Old 12-06-2014, 01:11 AM
Re: Html
Originally Posted by andrew59it View Post
Sorry....
Moreover discovered html works the first post after I open AF , the second post doesn't work again. Made a setting reset in chrome but the same thing....
