Old 07-29-2014, 04:56 PM
chuck's chuck's is offline
99 T/C strut noise
I am experiencing an annoying noise from the front struts when passing over bumps. I do not believe that the front end is bottoming, but it seems to give a deep thud sound. It is not a tin sound, but more like something loose and insulated. What is a jounce bushing? Are these something in the strut assembly and susceptible to getting loose? I have read about the springs could be the culprit, but could it be that the front spring is bottoming and the strut is hitting a bottoming rubber ? Jounce bushing? Thanks for some help.
Old 08-29-2015, 10:59 PM
Re: 99 T/C strut noise
Wow, nearly a year later and I found the noise. It turns out that the left sway bar link joint was worn in its socket. Replaced this and noise is gone.
chuck's
Old 09-01-2015, 01:06 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Yup, sway bar links and bushings cause the majority of suspension noises on these vans. Thanks for coming back with the fix.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
