Old 07-28-2014, 02:31 PM
marvs10 marvs10 is offline
2000 s-10 all 3 brakelights out
I have a 2000 s-10 extreme 3 dr. v6,with all 3 brake lights not working.All other lighting works ok. Fuses and bulbs check ok. In searching the previous posts,I think I understand fhat the 3rd brakel ight being out also would rule out the hazard switch and the combination switch since the power for it does not go thru these switches. Am I correct in thinking that this leaves the brake kight switch or the wiring from this switch as the likely culprits?
Old 07-28-2014, 02:55 PM
aleekat aleekat is offline
Re: 2000 s-10 all 3 brakelights out
I would lean towards switch, and they are pretty cheap non-dealer.
Post back, that's what makes Forums Work.
The Following User Says Thank You to aleekat For This Useful Post:
marvs10 (07-29-2014)
Old 07-29-2014, 12:27 PM
Can anyone direct me to a wiring diagram for this brake light switch,so that I can check it before buying a new one?
