Old 07-28-2014, 09:11 AM
comet240 comet240 is offline
2004 door pin removal
hi
my 2004 cav door doesn't close anymore as there is too much play
but how do you replace the door pins as I cant see no clips to remove ththem and hammer out the pin and then the bushing like other doors
so what do you I need to do
Old 08-06-2014, 11:00 AM
Re: 2004 door pin removal
ok I take it no one knows how to remove those door pins from a 2004 cav??
online they talk about different models that you can just punch them out but here you cant its mushroomed at the top so I tried cutting torch but flam too big to work in there
I cant get a cutting disc in there
someone has had to replaced door pins
Old 08-18-2014, 11:31 PM
thzpcs thzpcs is offline
First remove the door spring then knock the upper pin down and the lower one up until they come out. have a long 2x4 under door propped up by floor jack
Old 08-19-2014, 06:47 AM
I talked to a mechanic at candian tire, he told me 2004 cav you cant punch them out,
you need to replace the entire hinge, as I tried to punch out but since the pins are mushroomed I tried to use the cutting torch to cut them out
