Old 07-27-2014, 10:08 PM
tinkering's Avatar
tinkering tinkering is offline
In the 200 Club
Question Wire Center High Mount Stop Light?
1996 Cheyenne 3/4 Ton 4x4 Long box
I put a cap on the box and the inspection guy told me I had to have a Center High Mount Stop Light on the back of the cap itself (because the back of the truck cab has one). I mounted the fixture and routed the wires down the box post under the truck box (I included a plug connector before it goes down the box post, so I can unplug the cap easy when I want to remove it).
Now I began to think... I can't just tap into the brake light wire at the rear bumper because the CHMSL will come on too when a signal light comes on. Do I have to run a CHMSL feed from the fuse box or somewhere up front, all the way down to the rear bumper? Does someone know where to locate this feed, or do I have to reference a schematic in the manual? Guess what? I don't have the manual.
While I was at it I installed a cargo light fixture inside the cap. I guess I could run that feed down from the front too while I am running the CHMSL wire. Am I looking at this right or does any body have some help ideas?
1923 Model T 'Stake' Truck, see in Legends of the Fall
1949 Chevy 3/4 Ton, had 214 ci now 235ci
1959 Dodge Mayfair
1986 Ford Ranger 4 cyl
1993 Pontiac TransSport 3.8
1996 Chevy 3/4 Ton 4x4
1999 Oldsmobile Alero
2004 BMW 330i
Old 07-28-2014, 01:35 AM
tinkering's Avatar
In the 200 Club
Re: Wire Center High Mount Stop Light?
If you don't have any absolute details, can you at least tell me if I am barking up the right tree?
1959 Dodge Mayfair
2004 BMW 330i
Old 07-28-2014, 09:50 AM
j cAT j cAT is offline
Re: Wire Auxiliary High Middle Stoplight?
you are braking up the wrong tree.
you tap the feed for the CHMSL at this fuse. then installing a 10A fuse in your new feed at this connection , then run wire to your CHMSL on the equipment you mounted .
The Following User Says Thank You to j cAT For This Useful Post:
tinkering (07-28-2014)
Old 07-28-2014, 10:09 AM
tinkering's Avatar
In the 200 Club
LOL I hope I don't go braking up any trees!
Which fuse, the STOP/HAZ (Stoplamps) in the fuse box under the hood? That makes more sense to me than the fuse in the box under the dash Thanks j cAT .You have helped me once again. I just clicked you another 'Thanks'.
1959 Dodge Mayfair
2004 BMW 330i
Old 07-28-2014, 11:16 AM
777stickman 777stickman is offline
The STOP/HAZ fuse is hot at all times. You don't want to tap into that. For the CHMSL you just need to tap into the COLD side of the Brake Switch.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
Old 07-28-2014, 11:27 AM
tinkering's Avatar
In the 200 Club
Thanks. That makes more sense. No need for an inline fuse holder either? I clicked a 'Thanks' for you.
1959 Dodge Mayfair
2004 BMW 330i
Old 07-28-2014, 11:33 AM
tinkering's Avatar
In the 200 Club
How do you contact a moderator? I want to correct the name of this thread to 'Wire Center High Mount Stop Light?'
1959 Dodge Mayfair
2004 BMW 330i
Old 08-14-2014, 11:19 PM
tinkering's Avatar
In the 200 Club
A guy on the fullsizechevy.com forum gave me a wiring diagram indicating a CHMSL feed in the trailer bundle at the back of the truck. Here is the link: http://www.fullsizechevy.com/forum/g...ml#post5865948
Thank you all a bunch for your help.
1959 Dodge Mayfair
2004 BMW 330i
