Old 07-26-2014, 02:20 PM
parkerb parkerb is offline
2 teflon seals at steering rack
hi all,
replacing the steering gear/ rack on my '02. ford gave me 2 different sized white teflon o-rings for the hose connections, but i'm finding i need 2 of the bigger sized ones. both of the worn o-rings look the same size.
anyone know if this is correct or do i stretch the smaller one on which side?
tia,
parker
Old 07-26-2014, 03:59 PM
12Ounce 12Ounce is offline
Re: 2 teflon seals at steering rack
I think you are correct. I believe I remember 4 O-rings coming with my replacement racks. The smaller ones go on the inner location between tube and movable fitting ... I've never replaced. If you are concerned about the outer-most fitting ... I've used a wrap or two of Teflon tape instead of the O-ring and its done just fine.
The Following User Says Thank You to 12Ounce For This Useful Post:
parkerb (07-26-2014)
Old 07-28-2014, 07:04 PM
just in follow up, the p/n mentioned in the service manual is 388898-s. that is the larger of the 2 o-rings. the small one is 388897-s. i have a feeling that is for the other end of the pressure hose that connects at the pump.
