Go Back   Automotive Forums Car Chat > Oldsmobile > Eighty Eight
Eighty Eight Includes the '97-'98 Regency and '96-'99 LSS Models
Old 07-23-2014, 02:44 PM
Butters16 Butters16 is offline
Question 1998 delta 88 electric issue
Hi
First post on here and question, I have a Delta 88 that i'm triing to repair. Customer said it quit running when he used the power windows, after it quit the windows wouldnt work and the fuel pump dont cycle (power seat stop working also) . Has power at all fuses and fuses test good but havent been able to figure out why the power loss. Hope someone had same issue and hes some insight on this. Thanks
Old 07-23-2014, 06:51 PM
Tech II Tech II is offline
Re: 1998 delta 88 electric issue
My guess would be loss of ground......pull the sill plate trim from the door openings, and stick your hand under the carpet......if it is wet, you could have a corroded ground or grounds or you could have a corroded splice that goes to a ground.......one way to prove this, is run a redundant ground to one of the circuits that is not working......find it's ground, and attach the redundant ground to it....if the circuit associated with it now works, you know it's a ground problem........
The Following User Says Thank You to Tech II For This Useful Post:
kdizzle111 (08-10-2014)
Old 07-23-2014, 07:14 PM
maxwedge maxwedge is offline
A990 racer
Thumbs up Re: 1998 delta 88 electric issue
Again Tech11 is on the money!
Old 08-01-2016, 04:36 PM
Daniel Fuller Daniel Fuller is offline
Battery keeps going dead won't take a charge won't jump off alternators Good batteries good according to advance what would be the next step
Old 08-01-2016, 10:05 PM
aleekat aleekat is offline
Voltmeter. Static voltage, starting voltage, running voltage.
Post back, that's what makes Forums Work.
