Go Back   Automotive Forums Car Chat > Buick > General Discussion
Old 07-22-2014, 07:57 PM
i_hate_cars38's Avatar
i_hate_cars38 i_hate_cars38 is offline
Lost In The Darkness
Thumbs down 2003 buick lesabra tire monitor is junk
i have a 2003 Buick lesabra
it has the gauge cluster you can flip through
i found the tire pressure sensor is junk
my one tire went down to 20 or so no alarm what 5 pounds or less
and it wont tell which tire
i called my shop a charge to get it set to the right pressure
for half the price walmart has those caps that show pressure
im getting those my dad says try them and there cheaper than the shop
how expensive a car do you have to but to have the readout on all four i seen it once
and why put a monitor that does nothing on this car even if the right pressure you play which tire is it
beats me on of those things in life i guess
All the great things are simple, and many can be expressed in a single word: freedom, justice, honor, duty, mercy, hope.
Winston Churchill
The most difficult phase of life is not when no one understands you,
it is when you don't understand yourself.
«It's good to know that if I behave strangely enough, society will take full responsibility for me.»
Old 07-22-2014, 09:01 PM
Tech II Tech II is offline
Re: 2003 buick lesabra tire monitor is junk
As you scroll through the data list in the DIC, you should get pressure readings for each tire.......the problem occurs when the tires are rotated.....every time the tires are rotated, the tire positions have to be relearned.....if they aren't then the readings you get from the DIC (driver information center) will be wrong.....for example, the DIC may show the LF tire has 25 psi.....you check it with a gauge, and it reads 30 psi......turns out, maybe the LR tire may have 25 psi, even though the DIC shows 30 psi......this is because the tire positions were not relearned during a rotation....
Old 07-22-2014, 09:15 PM
strange my car has never shown that
that is exactly what i want
i think i got a lower less fancy model of this year
it ony reads this word for word
tire pressure
normal
or
door bell and readout
low tire
pressure
moron car what tire
the cheap version they should leave it out more of a headache then a help
i love the ones that show picks of the tires front rear and shows each tires pressure
o well walmart time
Winston Churchill
Old 07-22-2014, 11:00 PM
aleekat aleekat is offline
really cheap pressure gauge. Under $3, any auto parts store. Check them yourself once a month. If you are the drive and forget, that why folks buy new cars every 3-5yrs. No preventive maintenance. Modern cars will go well over 100K if you take care of them.
Post back, that's what makes Forums Work.
Old 07-22-2014, 11:12 PM
thanks allot i just bought one yesterday
im going to waste 10 bucks and try those tire caps that supposedly stay green untill below 32 pounds
my dad said there ok and work
i basically already said forget this junk tir monitor nex shop visit i may try to shut off
thanks
Winston Churchill
Old 07-23-2014, 03:06 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
As you already figured out, your system does not specify which tire is low. It's designed to detect differences in wheel speed with the ebcm. It should read "low tire" when one tire is 10psi or more lower then the others. Assuming all tires are set to 35 and one is 20-25, the message should come on. If all the tires are the same, but set too low, it wont come on. So, set all tires pressures, clear the message and drive it. When the "low tire" message comes back on, check all the pressures and see which one is lower than the rest.
There are no individual tire pressure sensors...
Old 07-23-2014, 06:57 PM
Thanks for jumping in GMTech1, after rereading his post, I realized the mistake I made, thinking he had pressure sensors in his tires, since he said his tire pressure sensor is junk......
GMTech1 is correct, it is the difference in the speed of the tires that sets the tire warning off, not a pressure sensor.....good pickup GMTech1!
