Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 07-19-2014, 11:48 PM
mjdemaris mjdemaris is offline
Heated O2 Sensor
Question: What should the ohms be on a good HO2S?
On my Suburban, I have 4.5, but on my 2000 Montana, 3.4L, I have 5.9.
Mike
Old 07-20-2014, 01:06 PM
Tech II Tech II is offline
Re: Heated O2 Sensor
It might vary by different O2 sensors, but as long as you are getting a good reading I would think it's ok.......13 volts(car running) dived by 4.5 ohms equals 2.9 amps which is well below the 10 amp fuse.....
What problem are you having? Is there a code set?
Old 07-20-2014, 06:12 PM
Code is P0137
Old 07-20-2014, 10:49 PM
You do realize that this is a code for the O2 sensor, AFTER the cat, not BEFORE?
This code states the voltage is staying low......O2 sensors have two circuits, a heater circuit and a sensing circuit...measuring resistance has only to do with the heater circuit.....all the heater circuit does, is get the sensor to start operating sooner from a cold start......so resistance has nothing to do with this code....you either have a bad O2 sensor, or an opening in the harness to the sensing circuit of the sensor....
