Old 07-17-2014, 02:47 PM
qhad qhad is offline
1997 Chevrolet Silverado 4x4 z71
1997 Chevrolet Silverado 4x4 z71 transmission problems. 5 months ago I had it serviced and A/B shift solenoids changed along with filter and fluid. Now check engine is back on with P1860 code truck also has started shifting more firmly into second and at 65mph it gives a hard jerk. Any suggestions will be welcomed because local transmission shop wants $1800.00 to rebuild that I dont have.
Old 07-18-2014, 06:40 AM
j cAT j cAT is offline
Re: 1997 Chevrolet Silverado 4x4 z71
when you say shift solenoids do you mean the valve bodies ? the transmission valves get worn and then you loose pressure causing what you have now.
how many miles on this ? what is your tranny fluid replacing schedule ?
Old 07-18-2014, 09:46 AM
777stickman 777stickman is offline
P1860 indicates a problem with the Torque Converter Clutch PWM Solenoid. Need to check wiring at the tranny & VCM. Most likely you'll need to replace this solenoid.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
The Following User Says Thank You to 777stickman For This Useful Post:
qhad (07-18-2014)
Old 07-18-2014, 12:07 PM
(j cat) Not valve bodies but the 1-2 3-4 solenoids, filter and fluid changed so they told me at the time of service. It has 153K (miles)
(777stickman) the wiring and vcm your talking about, is it located on the outside or inside the trans... ?
Old 07-18-2014, 12:10 PM
with the mileage I would lean toward the valve bodies being eroded by the DEXRON III fluid. with pressure loss this then occurs.
I would replace the ignition switch first . many with this age vehicle have had odd type tranny problems .. even if it is not corrected this model . this mileage it should be replaced. contacts supplying power to transmission fail with the old switch...
if you replaced the tranny fluid every 70-100K miles then the valve bodies and other parts must be worn which causes a loss in fluid pressures...then the harsh shifting ...
Old 07-18-2014, 12:11 PM
Are you saying clean them or buy new ones?
Old 07-18-2014, 12:18 PM
I'm on a fixed income and have to save up for a rebuild, so my question is what repair can I have done until I come up with the money or it plainly needs a rebuild?
Old 07-18-2014, 02:37 PM
The VCM is the Vehicle Control Module located on the drivers fender well. Replacing the ignition switch would be a place to start. But with P1860 code, I would lean towards replacing that solenoid.
57 Chevy 210
qhad (07-18-2014)
Old 07-18-2014, 08:21 PM
you have this $1800 bill in your head ..changing the valve bodies of A/B is not that expensive. find a shop that has the ability to determine exactly whats wrong. the 1800 is for a complete half AZZ re-build with chinese parts.
these have computer controlled valves the drive train codes and the pressure test will show whats broke !
I know you have no money because you would not be driving this and your willing spend for a 1800 tranny job on a vehicle this old with high miles.
IMO drive it until it does not move then get another old truck. that way you will have time to save for another old vehicle.
Tags
4l60e , shudder , silverado , transmission , z71
