Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 07-13-2014, 10:50 AM
superdaddy6 superdaddy6 is offline
2003 impala broken spark plug rear
ok been at this for two hours now removed all kinds of shit to get at the plugs in the back.now after getting wires off go to remove and they break.now one came out clean it broke so just threads are in block.now the other one still has ceramic center i can get my fingers on it just cant pull it out.i have a back out tool.just not sure what to do with it.as for the last plug next to oxgen sencer i have not touched it yet.any help out there.please
Old 07-13-2014, 12:44 PM
Tech II Tech II is offline
Re: 2003 impala broken spark plug rear
Not quite sure what you mean.....
First, is it a 3.4 or 3.8?
If just the porcelain broke off, you can still grab the hex head of the plug.....or are you saying the metal hex of the plug broke off, and just the threads are in the head?
Old 07-13-2014, 01:10 PM
ok 3.8 and the end of the spark plug with the threads on it broke off and are still in block.and no the nut came out with most of plug.
Old 07-13-2014, 09:35 PM
Kind of rare for that to happen on a 3.8......have the plugs ever been replaced before, and were possibly cross threaded?
How many miles on the car?
Ever run into this again, work the plug back and forth, tighten/loosen, repeatedly.........use penetrant on threads, like PB Blaster.....
With plugs out, use a thread chaser on those threads in the head......when installing new plugs, apply light coat of Never Seize on the spark plug threads.....
As for the thread being stuck, let the threads get soaked with the PB Blaster....then try the proper size easy out to back the threads out.....
If you still can't get it out, there is not much room back there to try and cut it out, by filing a cut in the threads and trying to collapse the threads with a small chisel....there is also the problem of debris dropping into the cylinder.....so if the easy out doesn't work, the head might have to come off.....
Old 08-08-2014, 12:26 AM
la1's Avatar
la1 la1 is offline
for the 3.4L and possibly the 3.8L you can remove the 2 front motor mounts, the bog bone ones at the top front and pull the engine forward about 20 - 30 degrees I actually have a special tool I insert in place of one motor mounts after removing both. It has a long bolt that I can turn that pulls the motor forward. Its called an engine tilter and I knew the tool existed and I went to auto part stores looking for it I either got an attachment for a floor crane or a look from the parts guy like I had asked for the mythical sky hook.
