Old 07-13-2014, 08:42 AM
cruisn8ball cruisn8ball is offline
3.3 flex revs then dies
Howdy. Got 99 Grand with a issue. It'll run fine then you come to a stop light and it'll die. try to start it and it'll rev to 2000 rpm then drop to almost nothing then rev again then die. It may do this once or 2-3 times. If you keep your foot on brake and give it gas you can keep it running put it still revs. Once at highway speeds it runs normal. When you get home or wherever and shut it off for awhile it'll start and run normal. Had it in shop twice. No codes. Replaced pvc valve and hose, fuel filter. They said start replacing stuff till it stops. I don't go there anymore. Another shop said unless it does it for them they would'nt know where to start. Of coarse every time it does it, by the time I get it to shop it runs fine. I can do brakes, axle shafts, bearings but electronic fuel injection stuff still baffles me. Any help thoughts would appreciated. Thanx
Stumpy
Old 07-13-2014, 02:03 PM
DeltaP DeltaP is offline
Re: 3.3 flex revs then dies
No codes? Need to check the fuel pressure.
Old 07-15-2014, 03:44 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
The Idle Air Control valve (IAC) does what it says only when your foot is off the gas pedal. Would that apply to your problem? It's bolted to the throttle body.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
Old 07-22-2014, 07:15 PM
reece42 reece42 is offline
96 grand voyager se cut off or idles rough at stop sign or red light or while driving down highway its has 3.3 6cl motor and has no check engine light
Old 07-23-2014, 02:44 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
No need to hijack a thread and on top of it, post your problem twice.
