Go Back   Automotive Forums Car Chat > Toyota > Camry/Camry Hybrid/Vista
Old 07-11-2014, 11:18 PM
B4barrett B4barrett is offline
92 camry left rear window problem
My left rear window motor has not worked for several years. Suddenly several weeks ago the window just dropped. I knew the regulator had failed so I replaced the regulator and the window still was not working up or down. I ran 12 volts to the new motor and it works . I removed the master switch and disassembled and cleaned up still nothing. Ordered new master switch still nothing. All other windows work. Checked power coming out of the switch and it is there. Tried testing current at the motor plug and only get power on one leg. The confusing thing is that the wires that have power with the switch on up and down are not the same color at the rear door making me think the wires go elsewhere before going to the back door. Anyone have suggestions thanks
Old 07-12-2014, 03:31 AM
Brian R.'s Avatar
Brian R. Brian R. is offline
Resident Chemist
Send a message via Yahoo to Brian R.
Re: 92 camry left rear window problem
Check the wires for continuity at the point where they go from the body to the door. Opening and closing the door repeatedly many times causes them to break.
Forum Guidelines:http://www.automotiveforums.com/vbulletin/guidelines.html
"What we've got here is a failure to communicate"
Old 07-21-2014, 03:59 PM
Thanks for the help!
