Old 07-08-2014, 11:30 AM
ASJT3 ASJT3 is offline
Send a message via AIM to ASJT3
1998 T&C Pass window keeps falling off track
My 1998 T&C has a problem where the front passenger window keeps falling off the track (caused by hard slamming of the door).
I've gone into the door multiple times to pop the rear-most peg back into the white plastic window track "dog", but it keeps popping out after moderate door slams. Do the black pegs that are glued to the window wear out? (I think they're metal).
I think the plastic track dog is fine, and I make sure the metal clip is fully engaged with the window peg each time I pop it back in. The only reason I can come up with for this problem is that the window peg is worn down and has lost its "edge" and thus the metal clips can no longer retain it. Sound reasonable? Probably need a new window from junkyard correct?
2008 Tahoe SSV, 2007 Tahoe SSV, 94 GMC K1500, 93 Chev K1500, 91 GMC K1500, 2000 Wrangler Sport
Old 07-08-2014, 03:16 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: 1998 T&C Pass window keeps falling off track
I've done a few of these but have never had your problem. I take it the metal retainer clip is popping off too. Has it opened up a bit too far? I would take a very close look and compare the front peg and clip to the aft to see just how worn the aft is if at all. Can you see if the track is bent or damaged in any way? May need to remove the whole shabang to get a good look.
Not positive but pretty sure you have to replace the window if the peg is trashed unless you can make some kind of backyard fix on it.
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
