Go Back   Automotive Forums Car Chat > Classic Cars
Classic Cars Do you just love the classics?
Old 07-06-2014, 11:41 PM
btberte7 btberte7 is offline
axel inner seal
Hello Plymouth owners. I have a 36P1 business coupe. I am trying to replace the inner axel seals.
Plymouth made a bunch of changes in 1937 leaving my ride much different for seals. I have new seals that are in( one piece) with a spring and seal material that is supposed to be the inner seal. But on my rear axel it is different.
The term is an " oil washer " (2 pieces I think) where the back side is permanently attached with some sort of silver weld. I am thinking this is the back of the "seal" because I took the front washer out and there is a felt material about 1/2 inch wide. I am at a loss as to how to proceed because I could be messing with housing not the back part of the "seal". The books are calling this a "rear inner seal oil washer".
The book clearly indicates that the oil seal can be removed. I need tips on whether to grind the weld off or whatever I need to do. I really don't need to replace the whole axel housing.
Thanks
BT
Old 07-07-2014, 06:55 AM
maxwedge maxwedge is offline
A990 racer
Re: axel inner seal
Where did you get these seals from? Any discussion with the seller how to proceed?
Old 07-07-2014, 11:02 AM
Re: axel inner seal
The seals I bought from ebay they are correct for a 36p1 Plymouth. The original half of the "oil washer" is in the axel.
Thanks for reply. P.S. seller doesn't know about procedure.
Old 07-07-2014, 01:31 PM
A990 racer
Re: axel inner seal
I work these kind of cars in my shop, try and post some pics.
Old 07-08-2014, 09:25 PM
Re: axel inner seal
Working on photo's but added a drawing pdf picture of parts I see
(please see manage attachments) hope it helps in the mean time going Wednesday comment asap
Old 07-10-2014, 01:32 PM
A990 racer
Re: axel inner seal
Couldn't open it.
Old 07-11-2014, 02:18 PM
Re: axel inner seal
Trying a different format.
Thanks
Old 07-11-2014, 02:24 PM
Re: axel inner seal
Here is a revised drawing haven't had a chance to take pictures. The forum excepts this time of file. Please try to open it. The inner part has me wondering if it is part of the axel or seal if it was part of the axel I will have to remove it to put in the seals the part number calls for or whatever .Thanks Max
Old 07-11-2014, 03:26 PM
A990 racer
Re: axel inner seal
Still no good end to [email protected].
Old 07-12-2014, 01:38 AM
Re: axel inner seal
Sent drawing by windows mail.
thanks for link
