Go Back   Automotive Forums Car Chat > GMC > Sierra
Old 07-03-2014, 04:48 PM
89crown 89crown is offline
transfer case motor bad
my 2003 gmc sierra z71 transfer case motor is bad and is causing a service 4wd message to keep coming up on the dic. How hard of a job to replace that motor and solve my problem. Is it possible that I can do this job myself.
Old 07-12-2014, 10:16 PM
Re: transfer case motor bad
Don't understand why isn't anyone answering my treads I need help anyone out there that has done this type of job and knows what they are doing. Thanks (Please Respond)
Old 08-15-2014, 05:00 PM
Ok now I know I am not the only person in the USA that has a 4 wheel drive and that has had this problem. Someone help me out.
Old 08-15-2014, 09:33 PM
gmtech1's Avatar
gmtech1 gmtech1 is offline
Have you checked codes? Usually set 0327 encoder circuit code. The encoder sensor can be serviced. It's part of the motor assy. May be easier for you just to do the motor. Usually the front driveshaft needs to be pulled to allow room to replace the motor. The case will need to be in the "neutral" position to install the new one because the motors are shipped in the "neutral" position. You can turn the actuator shaft on the case with a pair of pliers. Not a tough job.
The Following User Says Thank You to gmtech1 For This Useful Post:
89crown (08-26-2014)
