Old 07-02-2014, 06:06 PM
stretch1999 stretch1999 is offline
Charging System
I have a 2001 Pontiac Grand Am SE 2.4L, 4 cylinder car. Had a bad alternator. Replaced alternator and battery. It all worked fine for about 2 days. Then more issues.
It runs fine for about 5-10 minutes. Battery voltage with alternator charging at 14.5 - 14.6 volts. Then the voltage drops to 12.5 and continues to drop. I have checked all the ground points that i could find on the car, no loose terminal connections to the battery, fusible link is intact. battery checks out good. Fuses are good.
Does anyone know what could possibly be causing my alternator to go from working perfectly to not working at all in 5-10 minutes. Im clearly missing something here. Any help to point me in the right direction would be greatly appreciated.
Old 07-02-2014, 06:11 PM
DeltaP DeltaP is offline
Re: Charging System
Bad regulator? Have the alternator checked out... on the car.
Old 07-02-2014, 08:22 PM
Tech II Tech II is offline
Re: Charging System
You won't be the first person to get a bad alternator out of the box.....
Old 07-06-2014, 07:12 PM
skibum1111 skibum1111 is offline
Send a message via AIM to skibum1111 Send a message via Yahoo to skibum1111
Re: Charging System
I agree. I had 3 in a row, at which point I went to a different supplier. And the 3 bad ones were not aftermarket if you read between the lines.
Rusting out Honda Civic $900
Fart cannon muffler: $300
Assorted stickers advertising products you'll never own: $50
Having your @ss handed to you by a brick shaped suv: Priceless.
Yup, I own the suv.
