Old 07-01-2014, 07:44 PM
DELOSBORNE DELOSBORNE is offline
orifice tube
I have a 2004 Buick lesabre, I need help locating the orifice tube please help.....
Old 07-01-2014, 08:22 PM
Tech II Tech II is offline
Re: orifice tube
Uh, why?
Old 07-01-2014, 08:25 PM
Re: orifice tube
I have had the system evacuated. They are telling me that the orifice tube or the accumulator is clogged they want 500 to replace those 2 things so I'm going to replace it then have it recharged.
Old 07-01-2014, 09:08 PM
brcidd's Avatar
brcidd brcidd is offline
Re: orifice tube
Highly unlikely either is bad- but OT is between the ports-on liquid line. very easy access
I've been doing a/c a long time, never seen a v-5 compressor clog an OT.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
Old 07-01-2014, 09:31 PM
Re: orifice tube
Condenser is clean, fans kick on full of freon, electro magnetic clutch is kicking on. Not sure what else it could be but it's blowing hot air unless the thermostat in the dash is broken
Old 07-02-2014, 06:22 AM
brcidd's Avatar
Re: orifice tube
"Full of Freon" ??? How do you know? The only way to know is to extract and weigh the refrigerant. 65% of what I see, has lost nearly all it's refrigerant-- V-5 pumps do NOT cycle when they go low on charge, and they will run continuously with only 5% of charge in them-- so I'd say you have lost nearly all your refrigerant (hint - compressor belly leaker-likely).
With the correct amt of refrigerant (2lbs) in your system, you have about a 95% chance it will cool- so find and fix your leak.
'99 GMC Yukon
Old 07-02-2014, 06:55 AM
Re: orifice tube
It was tested, and they said it was full.
Old 07-02-2014, 09:55 AM
Re: orifice tube
let's get a timeline on this thing.....
So, you had no cooling.....who diagnosed this?
Was the system low on freon, to begin with?
Did this garage, attempt to recover whatever freon was in the system? How much did they recover?
If it was low on freon, did they attempt to find the leak?
Or did they just pull a vacuum and fill the system?
Did they tell you what the pressures were?
The orifice tube will only clog, if the compressor launches, and sends debris into the system......so why didn't they suggest you need a compressor? have never seen an accumulator plug up......if the orifice tube was plugged, the system would cut out on high pressure....
So you say your system is full, the compressor is engaging.......have you felt the line after the orifice tube? Is it cold? Are the lines sweating? If they are you have a temp door problem.....
If they are not cold, you need to know what the pressures are on the hi/lo sides with the engine not running, and with it running and the A/C on max....
