Old 06-28-2003, 11:37 AM
srdjs1 srdjs1 is offline
Send a message via AIM to srdjs1
Problems with my 1996 jeep
Ok so they may be minor but still a pain to fix.
Dash board lights are starting to go on me for one.
Also when I run the front defroster it kicks in the air conditioner compressor but then it squeeks like a mother. When I unplug the power connection from it it doesnt squeel anymore, whats the deal folks any ideas please let me know cause with this heat I'm dyin here.
Keep it Real!
Keep it Loud!
Old 07-27-2003, 06:29 PM
CARAP CARAP is offline
I had the same problem. It had a new Goodyear Gatorback belt with the grooves that ran diagonal across the belt. Changed it for a plain belt. The slippage squeal went away.
Old 08-06-2003, 05:37 PM
rmousir rmousir is offline
The ac is made to come on when you use the defrost. it helps to keep it charged. That is normal for a jeep. The sound. get a new belt.
Richard
Sooner or later my mustang will be done!
Love my Jeep Cherokee!
Old 09-27-2003, 09:10 PM
goudy goudy is offline
the A/C comes on to dehumidify the air,
there are two options for the squeal
1. the best option, replace the belt
2. spray silicone on the belt, it'll slip, but you won't hear it, expect the A/C to run about 75% of the speed it should.
Old 09-27-2003, 11:21 PM
Squeel gone from replaced belt but now groan and leaking something!?
Thanks to all who replied,
I changed out the belt and squeel is gone but now we seem to have sort of a groan, and we have started leaking something. It doesnt squeek but sort of a low groanish moan that rises and falls as you rev or drive.
Thinking either water pump or power steering!?
It doesnt look like oil and is to far up for it to be from the tranni.
Any thoughts?
Thanks again,
Joe
Keep it Real!
Keep it Loud!
Old 09-29-2003, 11:37 AM
Po Pilot Po Pilot is offline
Send a message via ICQ to Po Pilot Send a message via AIM to Po Pilot
Sounds like your AC compressor is going and its leaking the Ester oil in it. Id take it by the shop and have it checked.
1996 Jeep Cherokee won't start JSValentine Cherokee 1 02-03-2011 02:51 AM
A couple of problems with my jeep... Tim040 Cherokee 14 04-05-2006 03:05 PM
Common problems with 1996 R33 GTR hatchy General Discussion 2 02-13-2004 11:27 PM
Many problems with 1996 Bonneville Keller0512 Bonneville 0 02-05-2004 10:17 PM
