Old 07-01-2014, 01:21 AM
chuckdeahl chuckdeahl is offline
1992 camaro
i have a 92 Camaro I don't know what transmission is in it can any body help me out the car started out with a v6 and the guy I got it from put a v8 in it out of a 82 pickup I do know it is not a 350turbo or a 400 I know what them pans look like if u can help thank u
Old 07-01-2014, 08:12 AM
maxwedge maxwedge is offline
A990 racer
Re: 1992 camaro
How would we know this from here? Look at the pan and match it up from trans pan id's on the net.
Old 07-15-2014, 10:38 PM
thzpcs thzpcs is offline
Re: 1992 camaro
There's no way to tell without a bit more information.
Old 11-10-2014, 12:07 PM
hallow843 hallow843 is offline
Re: 1992 camaro
Ok guys I also have a 92 camaro rs nd I have a problem with it idling funny, cuttin off, nd once I get it in gear nd start goin dwn the road it doesn't wnt to get up nd go like its suuposed to.... One thing for sure is that its loading bc I smell raw gas.... ive changed pretty much all sensors: IAC, TPS, nd MAP....
New EGR valve, new vaccum lines, new gaskets, new fuel filter.... only things I hadnt checked is fuel injectors, fuel pump, fuel regulator....
Any suggestions???
Old 11-10-2014, 10:39 PM
Blue Bowtie's Avatar
Registered Offender
Re: 1992 camaro
'92 RS - What engine? It could be TBI or possibly TPI is the original purchaser sprung for the option.
Presuming it's TBI, check standing fuel pressure. Inspect injectors with key on, engine off and fuel pump running. The pod gaskets sometimes fail, dumping raw fuel. The injectors can stick as well, or be inadvertently grounded through wiring problems.
