Go Back   Automotive Forums Car Chat > Chevrolet > Impala | Impala SS
Old 06-30-2014, 01:57 PM
scherp scherp is offline
Hard starting 2005 Impala
I have a 2005 Impala with 207,000 miles on it, that start hard/rough/sputers, but once running the engine runs fine. I have not tested the fuel pressure yet, but an interesting note, if I manually pull a vacuum on the fuel pressure regular to 12-15 psi and re-hook up the vacuum line the engine starts immediately. Any thoughts?
Old 06-30-2014, 06:07 PM
maxwedge maxwedge is offline
A990 racer
Re: Hard starting 2005 Impala
Yeh, bad pump or regulator. Check for fuel in the hose, what is the fp key on. Good fuel filter?
Old 07-01-2014, 11:59 AM
I just replaced the filter. Check for gas in the fuel pressure regulator and non came out and possibly I could smell gas. Did this after 15 minute drive.
Fuel pressure test
key on/engine off: 24 psi (but did not cycle the key, just turn on and checked meter)
engine running: 51 psi
engine running, vacuum off the fuel pressure regulator: 58 psi
leak down test: pressure started to drop slowly immediately after engine turned off.
Bad check valve in pump?
Old 07-01-2014, 02:41 PM
A990 racer
I would say the pump and reg. Seem ok. Possible leaking injector or two.
Old 07-01-2014, 03:03 PM
jyount jyount is offline
I'm with him, sounds like injectors to me as well. If you stick a mechanic's stethoscope on each you might be able to hear fuel flow. Has to be quite alote though. The worst part is where they are on this engine it takes atleast 4 out of that option. They are in the lower manifold. Maybe able to acess the two nearest the belt end, but doubtful...
Usually if the valve in the pump is bad the pressure leak down is rather quick, not slow like you say. Suprised its not throwing rich codes, that would narrow it down. I don't think there is any soft parts of the lines you could clamp and watch the gague, rule the pump out all together.
10 hours away from John Deere master certified
also master certified ASE tech. Exp. in both.
Went to school for cars, wound up staying with Deere dealer for a while, so schooling there too. Also couple years exp in GM and some GM training
Gave up wrenching for "Greener Pastures"
Current job: RN
2010 Silverado Z71 5.3L 65xxx
Wife's
2007 Suburban 1500 LTZ 5.3L 102xxx
Old 07-01-2014, 03:27 PM
Sorry, what I should have said the pressure started to drop by the time I got back to the gauge from shutting off the motor. The pressure drop steadily from the 51 psi to 10 within 5 minutes. It wasn't like the needle went from 51 to 0 immediately.
Old 07-01-2014, 08:30 PM
Tech II Tech II is offline
I doubt it's the injectors.....leaning towards the f/p regulator...
Old 07-02-2014, 08:05 AM
Tech II, why do you feel it is the the f/p regulator?
Old 07-02-2014, 09:58 AM
Because of your first post:
You say your fuel pressure is 51psi.......once running, you don't mention any problems....
The Following User Says Thank You to Tech II For This Useful Post:
scherp (07-02-2014)
Old 11-02-2014, 03:43 PM
I finally got around installing a new fuel pump that solved the hard starting. I went to my local library and accessed Alldata and printed out GM fuel pressure testing procedure and it pointed to the fuel pump.
