Old 06-28-2003, 10:54 AM
jspruill jspruill is offline
suburban
99 sub w/75k miles
This light comes on intermittently.
Specifically when climbing grades @ high RPM
this has been doing is on & off for approx 20K miles
It would go off within a day off it's occurrence and I figured it was poor spark at high speed.
Had to get it smogged (CA thing). It passed all output parameters with the exception that the test picked up an OBD fault. Chk Engine Light.
Had to take it to the dealer to be diagnosed. They indicated that the problem lies in the 5th piston misfire at high speed under stress.
the fix .... hone valve guides $2000.00
I have performed meticulous maintenance and always changes oil between 3 to 5K
I can’t believe this is the cause.
secondly- is there a way to reset the light/history so I can get the smog cert? dealer say's must fix prior to resetting.
My position is it doesn’t effect normal smog requirements-
I need more time to look into the alternatives but need the smog cert now.
Any suggestions?
Old 07-02-2003, 04:17 PM
4onFloor's Avatar
4onFloor 4onFloor is offline
right before you have it smog checked, you could disconect the battery cable for about a minute. That should wipe out the codes, but it's also gonna take out presets in the radio, and a few other things
Old 12-14-2003, 08:58 PM
stephenson stephenson is offline
Perhaps you could be more specific with the subject line ... this is in the Suburban threads ... far more likely to get responses, I think.
1996 Suburban air bag system ground 1993Suburban Suburban 1 07-05-2009 08:50 AM
1986 Suburban with a Computerized Quadrajet? 1993Suburban Suburban 2 05-19-2009 05:13 AM
99 Suburban starting issue... smithguy Suburban 4 05-06-2009 08:48 PM
1996 Suburban Misfire when cold P0307 1993Suburban Suburban 5 02-23-2009 11:00 AM
Suburban Were can i get a transfer case for my 1999 Suburban RingOfireNetAdmin Suburban 1 06-01-2005 11:14 PM
