2000 Taurus power windows and door locks not working
I have a 2000 Taurus and recently the power windows and power locks stopped working. They won't work from any door switch but when I use the key fob to unllock or lock the car the locks will work. However, the windows won't work from any door switch. I didn't see a fuse marked for the windows or locks. Any help would be appreciated.
Re: 2000 Taurus power windows and door locks not working
There's not a common fuse between the power windows and locks. Since the driver's door window switch is the "master" I'd suspect a broken wire in the accordion boot between the driver's door and the cabin. It's a pretty common issue. If you're comfortable reading wiring diagrams and making voltage measurements along with doing some disassembly of the driver's door panel, I can send you PDF copies of the power window and power door wiring diagrams. If you want the diagrams send me a Private Message with the request AND an e-mail address for you. Since I follow multiple forums here please include the vehicle model and model year along with the request.
The fuses for the power windows are all within the Central Junction Box - F211 (15A) - F226 (10A) - F210 (30A) - Accessory relay For the power locks in the Central Junction Box - F216 (15A) - F222 (20A) -Rod |
The fuses seem to be okay. The window switch is fine because I tried a new one and got the same results. I did notice that when trying to put the driver's side window down I hear a clicking sound that seems to be coming from the "Driver One Touch Down Relay" in spot C2051. Could this be the problem?
The one touch relay would not prevent the other windows from working, or the locks. My prime suspicion is still a broken wire or two between the door and cabin.
The wiring diagrams will be on their way to you shortly.... -Rod |
Could I please get a copy of those files as well I'm having the same issues
-Rod |
If you could send them via email that would be awsome [email protected]
Yikes, I just now noticed this request. The files are on the way to your inbox.
-Rod |
