Old 06-21-2014, 02:19 PM
venturenot venturenot is offline
Oil consumption on 2013 Grand Caravan
My 2013 Grand Caravan has 55,000 miles and I noticed that it is down about a 1 quart of oil from last oil change which was 3000 miles ago. Is this normal oil burn for this van?
Old 06-21-2014, 02:52 PM
RIP's Avatar
RIP RIP is offline
AF -Advisor
Re: Oil consumption on 2013 Grand Caravan
Can't answer that but a dealer will tell you if you're adding a quart every 1000 miles you're in spec. Sad isn't it. Which engine?
**We took the time to answer your post. Please give us some time and post the fix. It will help hundreds.
**Follow prescribed safety practices before attempting any procedures. Doubts? Consult a maintenance manual.
07 Fusion / 06 RAV4 / 06 Accord / 96 Gr Caravan
The Following User Says Thank You to RIP For This Useful Post:
venturenot (06-22-2014)
Old 06-21-2014, 03:56 PM
V6 Flex Fuel 3.6 Liter
Old 06-22-2014, 08:25 PM
Engine oil is fine, my mistake I should have read the dipstick it says check oil when hot. I checked the oil in the morning after it had been sitting overnight and it looked like it was down a quart. After realizing that the oil must be hot, I drove for about 30 minutes, parked on a flat surface and checked the oil after 15 minutes. I checked and rechecked and the oil level was fine, as a matter of fact actually it was slightly over filled.
Old 06-24-2014, 12:56 AM
Teddie Teddie is offline
I have always checked the oil when the engine is cold after sitting overnight and while running after driving it for a while after it has warmed up. The cold reading has no point, I just like to get the reference.
Old 06-24-2014, 01:12 AM
This is the first time I have driven a car that has only a hot calibrated dipstick.
I found this interesting link from car talk. It is worth a read http://www.cartalk.com/content/when-...-your-oil-when
Old 06-25-2014, 12:58 AM
RIP's Avatar
RIP RIP is offline
AF -Advisor
"Deep Dipstick" - Good Lord the CIA is everywhere - hilarious.
My 96 GC manual says "The best time to check the oil level is about 5 minutes after a fully warmed engine is shut off, or before starting the vehicle after it has sat overnight". The stick calibration must be a compromise between a hot and a cold engine. Pretty much follows what the article said.
