Go Back   Automotive Forums Car Chat > Lincoln > LS | MKZ
Old 06-21-2014, 09:04 AM
Tarunc Tarunc is offline
Very strange issues
First of all - Thank you guys in advance. I am posting this for my father who drives a 2004 Lincoln LS that is having some STRANGE issues.
The issues are related to the air conditioning and door locks...very very strange. I did a DATC diagnostic and the only code I got was 12 65.
Here is the issue... When the car is started and AC is on, it will blow cold air for a while. While driving, at some points the AC will start to blow hot air and the power windows will not operate...the door locks seem to be making a clicking sound, according to my father.
We have had the dealer check the car and all they did was replace a cooling wall or something for $500+....a complete waste and no fix. We have taken it back to the dealer twice and they cannot isolate the issue. Naturally i am coming to you guys to see if you have ever heard of such a bizarre issue....
I did the DATC diagnostic twice this morning and reset the system (cold booted) by pressing the defrost button. Once completed the system rebooted and blew out a puff of air.....I did the diagnostic again and when done hit defrost...same puff of air. Again, the only code it threw out as 12 65 - which I am not sure is valid for this car.
Old 06-21-2014, 09:52 AM
Re: Very strange issues
After a bit more discussion I have learned the following:
The AC functions and after a while the AC shuts off completely....when it shuts off the power windows do not function at all...no up or down....
Any advice appreciated.
Old 06-22-2014, 05:41 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Just taking a quick look at the wiring diagrams for the power windows and the EATC system for the 2004 LS there are no fuses or relays that are common to both systems. It's going to take some more investigation to narrow down the possibilities.
When you mention the "AC shuts off completely" does that mean the display shuts off for the EATC, the blower stops blowing, or the just the compressor clutch will no longer engage? If the EATC display goes blank, does the button illumination still work when the headlights or parking lights are on?
Similar for when the power windows stop working - does the button illumination still work? Do the power door locks work? Do the windows only stop working from the driver's door or do none of the power window switches work either?
-Rod
