Old 06-20-2014, 08:51 AM
mbaker33 mbaker33 is offline
2010 T&C - Rear A/C
Hey Guys,
I've got some trouble with my 2010 T&C Touring and the A/C system. I believe it is specific to the rear, but not 100% sure yet.
Here's the symptom, while driving home a few nights ago, I noticed a hissing sound from somewhere under the dash. Research led me to believe that the r-134a was low, so I bought a few cans and charged it up. I drove around yesterday with the fresh refill, and all was well. This morning, I noticed that I hadn't been running the rear A/C, and thus, not doing a full test. So, I turned on the rear A/C and within just a few minutes, started hearing the hissing sound again. Flash back to a couple of weekends, I replaced brakes/rotors and while inspecting after taking a test drive noticed some water pooling up under the rear passenger side tire. I checked it out, but at the time, it didn't seem significant until today when I started to put this all together.
SO, my question is, what would be leaking right above the tire? Is this something that is super common and I could somehow convince my local dealer to repair out of "good will" like was happening with the '06 model year with a similar issue? I've had to do brakes, rotors and as a result of not knowing that Chrysler calipers can't be pressed in, but instead must be wound in, replaced calipers, and also an EGR valve all at the same time. So, needless to say, I'm not excited about doing further repair.
Thanks in advance for your guidance.
Mark
Old 06-20-2014, 04:55 PM
brcidd's Avatar
brcidd brcidd is offline
Re: Rear A/C
As long as you are sure it is water- it is the a/c condensate water drawn out of the moist air that passes across the rear evap and drains out the drain tube- perfectly normal and to be expected if the rear a/c is doing its job.
Automotive A/C Engineer with:
'99 IH 4700 Toy Hauler
(2) '95 GEO Prizms both maroon
'99 GMC Yukon
'95 Chev 3500, 454 Dually Crew Cab- 145k miles-
Wife's Camel trailer puller.
'94 Astro- 370k miles
'94 Firebird Formula- 5.7L 180k miles- gone-
'92 Chevy Lumina Van 3.8L 264k
'86 GMC S-15 - 2.8L 154k
'87 Buick Park Ave . 187k
'86 Buick Park Ave 3.8L 199k miles- gone
'77 Chevy Vega- 2.5L 175k miles gone but not forgotten
'68 Camaro 396 4 spd RS/SS -72k miles-
