Old 06-28-2003, 08:10 AM
djdrew44 djdrew44 is offline
GMC Jimmy gauge & ignition key problem
I just purchased a 1997 Jimmy and found a couple of problems. The Temp gauge does not work. The fuel gauge reads erraticly, It goes all the way up & down while engine is running. The Ignition key wont turn to the lock position without pressing the manual release under the column. Are all these problems related? Maybe a BCM or PCM? Thanks, dru
Old 06-30-2003, 05:05 PM
that1guy that1guy is offline
do you have an automatic or manual transmission?
Old 06-30-2003, 08:43 PM
Automatic
Old 06-30-2003, 09:08 PM
pcv pcv is offline
It not a BCM/PCM problem. For your temp. gauge you need to replace the temp. switch. As for the fuel gauge, these vehicles were known for having bad fuel sending units. There are a couple test that can be done to isolate the problem.
The ignition switch is probably worn or the it could even be the rack that is worn. That you will have to get it diagnosed by a tech. Good Luck.
NOTHING LIKE AN OLD CAR.
1996 GMC jimmy surging 600cuin Jimmy 1 10-05-2010 06:37 PM
Blowing ECMb fuse 1990 gmc jimmy 350 bmxer20n Problem Diagnosis 1 07-10-2009 05:47 PM
Ignition Lock Cylinder & Worn Keys... Intuit Escort 2 02-18-2009 09:51 AM
1993 GMC Jimmy 4.3 4x4 switch problem kroms_001 Jimmy 6 01-22-2006 05:56 AM
93 gmc jimmy 4.3 vortex fuel problem logden5751 Jimmy 3 01-16-2005 02:40 PM
