Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 06-18-2014, 01:22 PM
Rebelicious83 Rebelicious83 is offline
Exclamation 99 Eclipse Spyder GS won't fire
I have a 1999 Eclipse Spyder GS with a 2.4 engine. Last night coming home from work I hit a pot hole in the road and the car died on me and wouldn't restart. It will crank but not fire. Fuel pump is kicking on. No fuses are blown that we can find. Any suggestions and help would be appreciated.
Old 03-05-2015, 11:22 PM
blackspyder blackspyder is offline
Re: 99 Eclipse Spyder GS won't fire
Same thing happened to me last thursday.... turns out that by hitting that bump i must of snapped the balance shaft belt which fried the crank sensor which fried the ecu and relay and in turn prevented the fuel pump to work..... also the spark plug wires are not producing a spark..... im not saying this is your issue but go through the easy steps first to try and narrow down the real issue..... check your battery and termial, check and listen for your fuel pump, check your timing belt, and check for fuel bieng pumped to the engine and if you plugs are sparking... hopefully this works if not then its a bigger internal issue
Old 03-12-2015, 07:26 PM
Talon69's Avatar
Talon69 Talon69 is offline
Send a message via AIM to Talon69 Send a message via MSN to Talon69 Send a message via Yahoo to Talon69
you do realize this post is over 8 1/2 months old lol
Current Cars
2006 Eclipse GT 6 speed MT (V6 3.8), mods so far- S Tech Springs, after market 18's, 2012 headlight Conversion, Greddy cat back exhaust, CAI, RRE Headers, Polyurethane Motor Mounts, NX Nitrous kit at 100 shot for now, RPM Window Switch, Triple Pod.
2003 Grand AM GT - official beater car for the winter lol
95 TSI AWD [email protected] (T-25)
Now fully Modded engine with 3,560 miles on it.SOLD
