Go Back   Automotive Forums Car Chat > Isuzu > Rodeo | Passport | MU
Old 06-16-2014, 12:15 PM
kenc195 kenc195 is offline
Intermitent charging system
1997 3.2 2WD 299,000 miles original alternator
3 times in the last month when I start up first thing in the morning dash warning lights are lit up and the electrical system is not charging. AC doesn't work and windows operate very slowly. A simple rev of the engine has resolved the problem. However, the belt is very tight (and I mean very) and there is no indication of it slipping.
This morning, a rev didn't solve the problem. I only work a few miles from home and my mechanic is also very close so I just figured to head that direction. About 1/4 mile later charging kicked in and everything worked just fine.
I hate Intermittent electrical problems Where to start.
Life is good with my 97 Passport
Old 06-17-2014, 07:32 PM
amigo-2k amigo-2k is offline
Isuzu Guy
Re: Intermitent charging system
I would replace the alt ... I believe there is a voltage regulator within the alt that only charges the battery once it gets to a certain level (it doesn't need to charge the battery all the time).
Also, if you battery is nearing 5yrs it would probably be worth swapping that out too ...
-Ryan
Isuzu Moderator
Car Show Tips
Operations manager with a results-driven passion for process improvement
FAQ 98-04 Isuzu Rodeo, Rodeo Sport, Amigo, Trooper
SOLD - NOV2015 - 2000 Amigo, V6, HT winter, ST summer, 2wd
Old 06-17-2014, 07:42 PM
DeltaP DeltaP is offline
Ditto on the alternator. The brushes are worn out and brush springs are weak.
