Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-15-2014, 11:02 AM
blparrot blparrot is offline
1997 Chevy Malibu stub shaft.
I am currtent trying to remove the stub shaft from a 1997 Malibu and am having great difficulty. Anyone on here tackled this before? Any help would be greatly appreciated.
Old 06-15-2014, 11:14 AM
DeltaP DeltaP is offline
Re: 1997 Chevy Malibu stub shaft.
You talkin about a rear axle stub shaft?
The Following User Says Thank You to DeltaP For This Useful Post:
blparrot (06-21-2014)
Old 06-15-2014, 11:16 AM
No, the stub shaft comes directly out of the transmission and goes directly into the CV Joint shaft. The car is front wheel drive.
Old 06-15-2014, 11:45 AM
Is the axle assy out of the car and you're trying to separate them? There's a circlip on the end of the shaft holding it in. If its out of the car prop it up in a bench vise and put a vicegrip on the shaft using a hammer to drive the vicegrip away and out. On the other hand if its separated from the half shaft and still stuck in the trans/diff a combination of prybars,vicegrips and contorsions worked for me. But Kent-Moore has a tool I don't quite remember the number,( J-41228 ?),puller and a slide hammer. Make sure you replace the circlips and case seal.
Old 06-15-2014, 02:14 PM
I made a tool that clamps on to the stub shaft, I attatch slide hammer. Have rotated 2 or 3 degrees and slide tapped it a couple of rotations, but it dosn't seem to move. I have slide hammered it few times and it does not move. Worried I will break something!
Old 06-15-2014, 06:43 PM
maxwedge maxwedge is offline
A990 racer
You use 2 pry bars and pry/rock the shaft side to side as you pry it outwards.
The Following User Says Thank You to maxwedge For This Useful Post:
Old 06-16-2014, 10:58 AM
Tech II Tech II is offline
I think this happens on a 4T40/45E tranny...need a special tool to separate it....also before putting the stub back in, now would be the time to replace that axle seal....
The Following User Says Thank You to Tech II For This Useful Post:
Old 06-16-2014, 05:17 PM
Teck II, a special tool? Different from the one I made to clamp on shaft and attatch to slide hammer? I'm going to get the vin#, get with chevy dealership and find out which transmission I have!
Old 06-16-2014, 08:14 PM
If a 4 speed auto, with no dipstick, it's a 4T40E or 4T45E.....
Old 06-17-2014, 03:34 PM
slls slls is offline
This is what the dealer is suppose to use.
The Following User Says Thank You to slls For This Useful Post:
Old 06-17-2014, 07:14 PM
Yeah, thats it! Thanks slls. But even with it you can still get a stubborn stub now and then.
Old 06-18-2014, 08:01 AM
Forgot to mention......you not only replace the seal in the tranny, you replace the contact surface on the stub shaft also....
You know the procedure for checking fluid level?
Old 06-21-2014, 07:01 AM
Thanks to everyone for the help!! Got it out with slide hammer and crowbar. Rotate & pop it. Rotate & pop. The C-clip broke, so far I was able to get about a third of it with a magnet, the other piece must have fallen where the axles ride. Is this ok or do I have to get the rest of it out?
Old 06-21-2014, 07:11 AM
No, I do not! Crossing bridges as they arrive. Any help would be apprciated!! Many Many Thanks!!
blparrot
Old 06-22-2014, 03:40 PM
I would try to get the rest of the clip. Can't be too far.
blparrot (06-23-2014)
