Go Back   Automotive Forums Car Chat > Pontiac > Bonneville
Old 06-11-2014, 03:10 PM
rodcheco809 rodcheco809 is offline
Wont start
1995 Pontiac Bonneville cranks but wont start.
Ive replaced the crank sensor and also the cam sensor with no luck,
the car cranks with no start, when i used starter fluid the car runs, when i stop using fluid it shuts off what could it be
only has 38,000 Miles on it.
Old 06-11-2014, 04:05 PM
Tech II Tech II is offline
Re: Wont start
It means you have a fuel delivery problem......either there is insufficient fuel pressure or the injectors are not firing....does the SECURITY light go out after 5 seconds, when the key is turned to "on"(don't crank the vehicle)?
You will need to check fuel pressure at the schraeder valve on the fuel rail.....if ok, need to check the injector harnesses with a noid light...
Old 06-11-2014, 04:38 PM
Re: Wont start
OK before I replaced the sensors I check the fuel pressure and was getting fuel. But the injectors wouldn't fire. Yes the security light does go on for 5 seconds and then shuts off. And then I try to crank.
Tags
1995 , 3.8l , 3800 , bonneville , pontiac
