Old 06-10-2014, 03:45 PM
Sleeepy Sleeepy is offline
1990 buick lesabre wont start
i have a 1990 buick lesabre motor is a 3800 and it runs fine until the motor warms up and then when i shut it off it won't restart for about an hour after i shut it off. it's not over heating it has a new fuel pump. any advise on this problem, thx joe
Old 06-10-2014, 04:06 PM
Crvett69's Avatar
Crvett69 Crvett69 is offline
Re: 1990 buick lesabre wont start
i would suspect your ignition module mounted under your coil pack or inside distributor or the crank angle sensor. you can get a bottle of freeze spray to check your module or see if it has any codes
Old 06-10-2014, 04:12 PM
how do i use freeze spray to check it.. this is all new ball game to me. i'm the kind that if it breaks i can fix it, but this is 1 of those things i that i just can't seem to pin down
Old 06-10-2014, 04:16 PM
Crvett69's Avatar
if its the module mounted under the coils get a can of freeze spray, wait till it acts up then spray it with the spray to cool it back down then try it and see if it starts
The Following User Says Thank You to Crvett69 For This Useful Post:
Sleeepy (06-10-2014)
Old 06-10-2014, 10:28 PM
Thanks a million I'll try that
